jkwebbie
Why do you say the junkyard swap isn't even a comparison?Lol, Dynatrac for the win
Junkyard isn't even a comparison..
Sent from my SAMSUNG-SGH-I747 using WAYALIFE mobile app
.......Because I don't see how you could compare a 10-20 year old axle that is not designed to be a direct bolt in application v.s. a brand new axle specifically designed for the JK. If you throw in the new pricing of the PR 60/60, it makes even more sense
Yes they aren't directly bolt in, but if you're changing up your suspension while doing an axle swap, it makes sense to me, and there's companies out there that do make the swap kits for Super duty, Kingpin 60, and 14 bolt axles. Dynatrac does have new pricing packages, but if I remember correctly, Grubbicon swapped in his junkyard axles, custom long arms and ORI struts for the cost of the ProRock 60 front. Hell you can probably make 14 bolts front and rear for around the same price probably, if you wanted something different lol
Yea true. They are an option, just not the easiest I guess. It would be sweet to have 14 bolt front and rear though lolDue to the fact that they are not direct bolt in, you cannot compare the two. They're simply another option.
You haven't wheeled with Scott, he would break a ProRock lol. It was also down for a year because he had other Jeeps to go wheeling with, so he wasn't in any kind of a hurry. Hell he didn't touch it for like 4 months straight because he had that beater YJ he was wheeling almost every weekend lol.Don't forget that these axles which are suppose to be stronger and hold 40's he has broken a few shafts and other parts which caused him to spend more money. Doesn't seem like a smart investment to me at all. Plus his jeep was down for almost a year due to the swap. Once again not smart.
He wheels hard but he definitely couldn't break a pro rock.You haven't wheeled with Scott, he would break a ProRock lol. It was also down for a year because he had other Jeeps to go wheeling with, so he wasn't in any kind of a hurry. Hell he didn't touch it for like 4 months straight because he had that beater YJ he was wheeling almost every weekend lol.
He couldn't break the housing or anything, but I'm sure he could break a shaft lol. Those u joints he replaced where crazy lucky to be swapped out in the larking lot and not on Walden's Ridge lolHe wheels hard but he definitely couldn't break a pro rock.
Sent from my SM-G935T using WAYALIFE mobile app
Didn't Eddie break a rear shaft in his Prorock with the 3.8 still in it, like wayyyyy back?
Those shafts were old lol he couldn't break an rcvHe couldn't break the housing or anything, but I'm sure he could break a shaft lol. Those u joints he replaced where crazy lucky to be swapped out in the larking lot and not on Walden's Ridge lol
Ah ok. I forgot he ever ran the Trail 60 lol. That does make a big differenceThat was a semi-float.
Yea they were! Mine only have 50k on them, so hopefully they last a shit ton longer than his lol. And idk, he if he knew he had RCVs in his axles, he would definitely be hitting shit harder lol. Plus if he runs those stickies, he has a helleva lot better chance of snapping one lol
