There are long arm kits that are bolt on only but the best option is to always weld.
I understand most are weld on and it's better but this kit is a full bolt on or weld on its up to the installer that's what it says on evos website
Sent from my JK
I have a buddy who will weld for me but from what it says online you do not have to weld anything if I don't want to
Sent from my JK
Both are correct. It's a bolt on OR weld on LA system. Only the high clearance kit requires weld on for the rear
Sent from a migrant connectivity device
Any problems that you ran across while installing lift that I should know about before I order because every lift has one or two parts to it that make you wonder why you didn't just pay someone else to do it lol but I love being able to say everything on my jeep I installed !! That's just me though.
Sent from my JK
Forgot to add that on a '12 or newer the exhaust trumpet needs to be cut and turned around for clearance.
thanks for the input i thought it can be a bolt on if you want , i plan on doing it bolt on till i eventually get my coil overs than ill have everything welded in place but for now it will be bolt on when i order it :wings:
Mine is currently still on the lift so i wont be driving it until I get back from Austrailia in November, but it'll be finished by than.
I have a lot of angles of the kit.. as the shop send me atleast 20 pictures a day, so if you need any... just ask.
Anyone have any long term updates on the kit?
