I'm running the spacers. Haven't had any major problem with them other than the issue OverlanderJK was talking about as far as hitting the crossover pipe. The other problem I've had is the muffler hitting the heat shield since the exhaust has to be pushed back to fit the spacers, nothing a little adjusting didn't take care of. Also noticed the pipe over the axle hits the crossmember on occasion. But the spacers are a good 'bandaid' until I save for a front driveshaft.
I just took the lip of the heat shield and bent it out straight couldn't stand the rattle, problem solved
Sent from my iPhone on the west coast of florida
Trust me your stock shaft is not that strong. I have spacers and new front DS and like said before just cause your boot rips off does not mean your DS is bad. I have yet to see a custom DS come with a boot.
Stock shaft is stronger than a 1310.
Conventional wisdom says don't waste the $150 on spacers. Save up for the shaft and do it once.
I do agree, it's not the boot for the slip joint tearing that's the issue....it's the boot at the transfercase that is an issue.
I hope no one paid $150 on spacers when you can get them for $40 bucks that would just be a sad story and yes a waste of money I got them just to push it back some closer to the cross member to protect it a little.
Yes, mine were $40 from Rough Country. Wanted the lift but didn't have the money for a front shaft so I went with spacers. Had to have something to drop and move the crossover back enough to clear the shaft, it would rub the exhaust over a small bump without the spacers
My bad. AFE's delete is ~$100 and spacers can be had as low as $20 from rugged ridge. That'd be quite reasonable as a bandaid.
Sent from a a few tin cans and some string.
Not sure as how you see it as a band aid when it pushes it back to the cross member and keeps it better protected from getting crushed by rocks. From the way I am seeing your logic you must have some straight pipes coming out the fender off the header that way it is fully out of the way?
Get a drive shaft when you can. The drive shaft contacting the crossover pipe is just one of the problems. The end of the drive shaft coming out of the transfer case that's the other problem I just replaced one the jeep had 30,000 on it the boot was shoot with a 3.5" AEV lift.
I have a long arm lift and have had no prob with it contacting the loop. Which lift are you running? Because the vehicle was engineered with the loop I wouldn't delete it. I'm sure they didn't just put it in for fun..haha. Additionally I purchased the AFE Y-pipe relocation which moves it behind the trans. It work but comes with its own set of problems. With a manual trans the pipe makes contact with the trans mount on the passenger side causing a vibration at certain RPM's. Also its a two piece configuration and try as I might I can't get it tight and have condensation leaking from the connection points. For this reason I saved my stock Y-pipe and may eventually put it back on.
Sent from my EVO using WAYALIFE mobile app
