3.6 knocking sound?
Guys, I need help. My battery is completely dead. I am not sure if I messed up here with a possible ground cable. I know for a fact some ground wire was connected to the body but when I put everything back together I could not find what was connected here. I connected that black wire to the battery because it kind of made sense the way it was bent, but now I am starting to think I screwed up.
View attachment 425475View attachment 425476
The negative terminal is really crappy on the JK. Has happened countless times to me where it seems the Jeep has absolutely no power. Looks fine to me but try to wiggle the negative terminal around or remove and reinstall making sure the conical nut closer to the end is tight on the clamp. I've found it works more consistently without those anti corrosion felt washer things so it sits lower.
Waiting for triple A to show up and give me a jump. Was thinking of heading to Autozone right after to test the battery
I keep a jump box in mine for such an occasion... But yeah get it tested and if it's good I recommend reinstalling both terminals without those colored anti-corrosion felt washers.
