Opps I ment height, thanks for pointing that out.Just to be clear, going from 3" to 4" springs doesn't give you more travel. You just ride higher into the same range of travel you already had. Shock length and bump stop determine travel range.
Yes, but you're just adjusting the difference of up and down, not actually gaining more total travel overall.But wouldn't his up travel be greater with taller springs ? due to the taller springs creating more distance between the bump stop and the pad or do i have it all wonky LOL
I may be wrong, but I think they only do a 3" extension.Does EVO recommend the same bump stop with both 3” and 4” coils?
They have four inch as well I was recently looking at them.I may be wrong, but I think they only do a 3" extension.
Well there you go.They have four inch as well I was recently looking at them.
Well there you go. [emoji41]
I know that when I was looking at the Enforcer kits a couple years ago, even the 4" kit came with 3" extensions. Maybe that's changed. [emoji848]
That was my understanding of how their kit was designed.
Let's not bring logic into this discussion.Wouldn't the taller bumpstops be for larger tires?
Not so much the spring size, but to keep from rubbing. Also for allowing longer shocks.
Goddammit. More logic.I have seen Eddie post comments about bump stops also being important to avoid over compression of the springs. But I don’t recall the details. Maybe he will chime in.
That looks similar to the equation used to figure out what your wife wants for dinner.
Lol Bingo!That looks similar to the equation used to figure out what your wife wants for dinner. [emoji1787][emoji23]
