2021JLUR
Will be getting a 3.5in lift soon. (Teraflex or Metalcloak or combo of both)
Will upgrade to larger tire from stock 33in KO2, 35in min or 37in max.
personally would like to put the 37 on, but will the oem axle's be ok with this?
(2021 front has CV joints)
I believe I will be using drop brackets to keep steering geometry the same.
Some places say using 8in wheel will work, others say 8.5in and another says use 9in.
What would be the best? (I don't believe the oem 8in will do the job)
Is there any other things to consider if using 37in?
(I know about the tire carrier but I will deal with that unless someone has a good idea that isn't expensive like Teraflex option)
(also plan on getting a Tazer to remap the cpu etc.)
