LG Innotek 521 2 CH Dashcam
Some boring stuff for now but figure its part of the Jeep and will include in the build. Someone might get something out of it anyway.
Installed the LG 521 2 CH dash cam for some extra security while driving and parked. I was choosing between 4 cams, the BlackVue, ThinkWare, BlackSys and the LG. The LG is a fairly newcomer to the dashcam market but they are a big company with global recognition and they did do their homework when they made this cam. It checks all the boxes for a 2Ch dashcam. Sleek and discreet design, good wifi connection to mobile device for viewing files and adjusting settings, great video quality due to their high bit rate recording, high temperature and lo voltage cutoff security built in to unit, excellent hardwire kit and simple and well thought out function at a reasonable price.
I hooked it up a few weeks ago and hard wired it to the fuse box. Once I get my TrailRocker installed I'm going to remove it from the fusebox and connect the constant to TrailRocker fused lead coming inside cabin and get the ACC lead from behind the Cig/Power outlet near climate controls.
This cam works great. I have it set up on "Event recording" so that its not constantly recording video but rather will only record once an impact (Event) occurs. It will capture video 10 seconds before the impact and 33 seconds after. If I see something on the road worthy of recording that I was not involved with I can simply tap the cam to trigger an Event recording.
In Parking mode, the Motion sensor is very sensitive even at the lowest setting. It goes off whenever a car drives by so I have it turned off with only the Impact sensor (highest sensitivity) on while parked. If I lived out in a remote area, I would probably have the motion sensor on as well at the mid to high setting to catch anyone snooping around the Jeep.
Last week, I had a new Event recording when I got in the Jeep and it turned out that someone parked behind me hit the Jeep while they were getting out of the spot. I caught the action and their plate number but there was no damage to my Jeep so I let it go.
The rear camera comes with a good quality cable with mini jacks on both ends. the cable is quite long but when I laid it out prior to install it appeared that it would not reach if I routed it down along the floor so I went up through the roll bar padding and had more than enough cable.
The front dash cam unit I mounted on the plastic trim above the windshield which is close enough to the glass to avoid glare but keeps it even more discreet, and, if I have to replace windshield I don't need to fuss with the cam.
