Hi,, I put on the stock trackbar, torqued to spec, centered the steering, but still get the shimmy. It's not D/W, just a shimmy in the steering wheel on bumps at highway speed. Going to try the barely used 2012 control arms and and throw on the shocks they come with....We'll see if the newer bushings help at all.
well, step by step is the only way you'll be able to find your problem. regardless, a track bar that flexes is still not a good thing and i would see if you could get that replaced. having one bad shock can cause a shimmy and so can a bad control arm bushing so, maybe you'll find your problem there. good luck.
