dpetersen1988
For the JL diesel
LOL!! Apparently, you're the self-proclaimed expert here.
Why does the loop exist and why is it needed? From my experience and from what i was told the loop is there because the manufacture realized there was two much power and had to slow it down, this also came from a guy that has been working on exhaust for over 30 years. I have a loop delete on my rig and have no problems and sounds amazing, but of course i also have the exhaust made by them as-well.
No, not a self proclaimed expert have a lot of experience with automotive and jeep also, just sharing what i was told, but if that is why jeep did that, that's pretty stupid with all the aftermarket exhausts and tuners u can buy.
Where can I buy some extra loops to get more power? My 3.8 is a tired dog.
These engines are tuned to get maximum horsepower. I think a lot of people don’t realize, getting 285 horsepower out of 220 cubic inches (3.6L), is no small feat. In the muscle car era of the sixties, getting one horsepower per cubic inch, was considered remarkable.
There is a reason why the loop exists. Deleting it may address clearance issues but it isn't really the best solution. Here are a couple of shots of what the loop should look like once flipped.
Yea that was remarkably for that time and quite amazing at the same time, and not easy to get 285 horses outta 220 cubic inches but it can be done, i guess there is a mix of information around.
Will the long arm bracket clear the exhaust without modifying it? Is it just the lower long arm that will hit the exhaust when the suspension is articulating?
I’m asking because I would like to try to install the lift myself then drive to a shop that will modify the exhaust for me.
You won't have to modify the bracket, just the exhaust. If you cut it right, it will weld in right
Did the magnaflow loop delete, mid pipe to route behind trans, magnaflow exaust, programmer with unlocked ecm, and intake on the 3.6. Noticeable power increase.
Are you guys saying that should of left the loop there?
Have you considered the fact he might have added a sticker to the side of his rig. That’s easily an extra 5hp.If you really believe you got an actual power increase worth mentioning, more power to you [emoji1303]
