2 drs with 4 drs springs, larger tires and pics and stats please.
Helps a lot. Thanks!
I showed you the 18/60 springs when I had the 37s,
Now, same set up with 35s,
A little more breathing room. The front end has a 3/4 spacer to help level it out.
Here's a difference in the springs I swapped. Shorter ones were stock on my two door, longer ones came from a four door. So, if I remember correctly, I went from about a 14/56 to 18/60.
I gained nearly 2 inches on front.
And about 1 1/2 inches on the rear.
For now, while saving for an upgraded lift, it does the job. No issues yet. Rides nearly like stock.
Hope this helps brotha!
I read somewhere that I'd need to change driveshafts after putting JKUR springs on my JK, or they'd fail prematurely. I'd like to get more input on that from those with experience.
I replied in that thread...do you wheel hard? As in high articulation I would have to say yes. Mine is fine. Service and logging roads like I run no.
Before 4dr spring
After 4dr springs
Bfg 35 km2
Trimmed fenders and pinch seams/rails
Gave me 1.5" of lift.
Not bad for $60 from wayalife member
Old Man Emu 2 " Suspension Lift for a JKU gave me a total of 3.5" of lift. Then installed 315x75x16 Dick Cepek Fun Country tires on the stock wheels with 1.5" spacers.
When money permits, i will buy wheels with the correct BS.
Rubinot
That is awesome. Looks great and tons of clearance. My goal was a little lift to keep COG low.
I can't wait to see the final product! I bought a lift kit designed for a 4 door for my 2 door. It was a 3.5" lift and I ended up getting a total of 5.25" out of the lift. With my 37s I ended up with over 7" ground clearance gain.
<img src="http://wayalife.com/attachment.php?attachmentid=119931"/>
Man! I just keep coming back to this to look at it - nice
So happy I ran across all this! I've been considering picking up jkur springs and shocks for my 2 door sport, and after seeing this I think that's what I'm going to do..
Got 18/59 springs a while back. Forgot to measure but got somewhere between 1-2" out of them. Tires are 285/75r16 Duratracs
