1977 Cherokee Chief Project Begins...
awesome project! looking forward to the updates
Thanks! Today I'll be replacing the ignition cylinder, door locks and re-keying the tailgate lock. Stay tuned...
This is awesome Tony! Looking forward to watching the progress and seeing it back in the road šŸ¤˜šŸ¼
Thanks! I can't wait to get this rig on the trail again. I think it still has some life left in her...
Awesome project! Will be following along!
Thanks!!
Awesome project. Even better that it was your father’s. I love the two door wide track Cherokees, especially with the 401. They’re beasts and will go anywhere! I wish I never got rid of mine.
I Agree! I think my dad would be proud to see his Jeep being brought back to life. I too have gotten rid of so many vehicles I wish I had today! Live and learn they say! Right!?
Not sure how I missed this yesterday but, so much AWESOMENESS right there. Can’t wait to see this come back to life so I’m subbed as well.
Awesome! Thanks!
You fixin to upgrade the brakes?
I've been giving that some thought! I know you can get a rear disc brake conversion kit for these so I might go that route. Have to do more research on that. But for what I plan to do with it, I don't really think it needs more than replacing what's needed.
Thanks again all! I really appreciate the support. I'll be sure to get some pics of today's project posted up ASAP. (y)
Forgot to mention...I plan to fix the ignition and door locks today. Back in the day, Jeep provided two square headed and two oval headed keys with each vehicle. The square headed key operates the ignition switch, front door locks and tailgate locks. The round headed key operates the glove box lock.
The new door lock keys came with oval keys. Question:
1. Would you replace the door lock keys as is and re-key the tailgate lock? or...
2. Would you rekey the new door locks to match the new square headed ignition key and re-key the tailgate lock to the square headed key?
Please let me know what you think. I'm leaning towards option 2.
It's been a coons age since I've had them apart, but I believe the lock cylinders use physically different mechanisms, thats why the 2 different key styles?
I would go option 2
It's been a while since I disassembled a Jeep steering column. Let's see how this goes.
After removing the steering wheel nut, horn cover, horn contact plate and cover, it's time to remove the steering wheel. don't forget to paint or scribe alignment marks on the steering wheel and shaft for assembly reference. This one already had alignment marks on the wheel and shaft.
After you remove all these bits, you will need to remove the steering wheel lock plate with lock plate compressor tool.
Lock plate and wire snap ring removed.
Next, remove the turn signal lever and switch.
Turn signal switch moved to the side.
To remove the ignition cylinder, place the ignition lock cylinder in the run position. Compress the lock cylinder retaining tab with a thin screwdriver. The retaining tab is accessible through a small slot adjacent to the turn signal switch mounting boss. The slot may not be visible due to casting flash covering the slot. If this is the case (as mine was) you will need to scrape or knock any casting flash out of the slot to gain access. One the casting flash is removed; you can compress the retaining tab with a small screwdriver while pulling the key cylinder out of the column.
This is as far as I got tonight. The bits in the column need a lot of cleaning and after careful inspection the turn signal switch, it may need replacing. I'll continue this adventure tomorrow...
Wow, this is a trip from memory lane - I changed out a standard column to a tilt version I found in a junkyard on my 71 Javelin years ago.
Funny how many parts they interchanged on AMC's back then. Pretty comical actually.
After years of sitting in the California high desert, my dad's 1977 Jeep Cherokee Chief (wide track) is finally getting some attention and I figured it’s time to start documenting the journey.
Here's a pic I took of my dad and his Jeep back in their heyday...
Now, the Jeep definitely needs some TLC. The last time it ran was back in 2011.
The plan is to take it in phases, beginning with the basics to get it running, driving. First step: replacing the ignition lock cylinder and both door lock cylinders. The old keys barely worked! Typical 40+ year-old FSJ stuff. I’ll also have a locksmith re-key the tailgate lock so everything is consistent.
I’ll also be doing a full mechanical refresh soon with help from The Jeep Farm in AZ, but for now, it’s all about getting the small stuff handled and building momentum.
This will be one of many updates to come hoping to turn this Chief into a reliable, road-ready rig while preserving its character and patina. Always open to advice and encouragement!
Thanks for reading very excited to finally get started!
...Tony
Apple Valley, CA
’77 Cherokee Chief | AMC 401 | TH400 | Quadratrac | Levi Edition
I am really excited to see this build! I had the near exact same Jeep as my first bought vehicle. It was a 1978 with the 360. Same color and Levi Edition. What an awesome project Tony!! Keep those pictures coming!!
