I'm running 3.73's and 295/7017's. Been happy. Also calibrated with Superchips. 2011 JK.
Ya, the super charger bit was a joke (for the love of GOD do not do that). You likely have 3.21 gears (which means you didn't have much torque in the first place). I would explore getting regearing done. For a pavement princess, you likely can go with 4.56 or 4.88 gears (more torque on the low end and higher RPMs at the high end). I went from 3.21's to 4.88's on a 3.8l and it was night and day.
If there is a chance you may start wheeling it, you might want to look into the more expensive option of replacing the front Dana 30 axle and housing with a Dana 44. If you wheel the D30, you will likely break it over time and it is expensive to regear twice.
I would check with Essentially Offroad in Murfreesboro (I know, the is hell and gone for you, but they are a good shop) for pricing.
I am a huge Preds fan, still play hockey and went to every home game in the 2017 cup run, love the handle man!
New gearing will make a huge noticeable difference, intake, exhaust & tune in comparison, not so much. Google "Jeep JK 3.8 Gear Chart" be sure to use the one for the automatic and keep yourself in the middle of the green area for a on street daily driver. Be sure you measure your tire size manually for the calculation. The 3.8l engine makes decent power, its the 42RLE automatic trans that kills the whole driving experience. I would skip the bolt-ons and go straight for gears.
Torin - It is a Sport trim level. It's actually my wife's JK that I bought her after she kicked cancer's ass! So, it is definitely a pavement ride. I assumed the bigger wheels and tires was part of the issues and had I known the HP difference between the 3.8 and 3.6, I would have shopped for a 2012 or newer. I'm stuck now because she is in love with it...lol I would welcome your recommendations on the regear. I am a grease monkey on the side but don't think I want to get into that work.
Our last Jeep was a 2011 sport as well. Was running bfg At KO tires in a 33 (they tend to run small so was probably a high 31 low 32) with 3.21 gears on a superchips tune, volant cold air intake, and afe exhaust. Did ok until one long fast 12 hr. slog from Idaho back to Portland towing our little bantam trailer that fully loaded is 700ish lbs. By the end it was gutless power wise (not that it had much before but was at least driveable) but I’m talking pedal to the floor to do maybe 5mph up a hill to the in-laws cabin at the end. Was quite a bit better the next day, but a long bit short of how it was before. We traded it in a couple months later. It idled fine, nothing wierd. Just permanent power loss. Never figured it out.
Congrats to you and your wife! Way to stay strong in the fight!
You said you used the programmer for a "tune" but did you use it to program the new tire size? If not, that will throw off the shift points and speedometer.
I don't disagree with the need for a regear, but start with the easy stuff. Don't invest in a gear job until you know what tire size you're going to end up with when you're "done" upgrading. [emoji41]
Man that’s crazy! Luckily ours isn’t that bad, it’s just the fact it feels like I’m having to really push it to get down the road. I can run 70 mph on the interstate but I have to keep the pedal hammered down for sure. Thank you for the feedback!
Thank you so much! She is a fighter and very lucky to have such a great outcome. We don’t take it for granite for sure as there are tons of folks who don’t win the battle! She’s always wanted a Jeep but “it was never the right time”. So, I say screw that and took some savings I had and found the perfect one for her. She is truly in love with it so I’m determined to get the driving experience better for her! Thanks again!!
You measured actual size, right? From the ground to center of the hub x2?Yes I mainly got the programmer to adjust the tire size and speedometer but went ahead and loaded one of the preloaded tunes as well. It did seem to help at first but it certainly needs some additional love to improve the performance. Thank you!
What exactly was wrong with the brake hose? Did it collapse internally?
I’m pretty sure the problem with the Jeep is your choice of hockey teams.
GO HAWKS!!
