Show Off Your Guns!
My wife is sick of my critter guns being all over. Found a solution. VEVOR gun rack. Simple, easy, cheap. Ready to rock and roll. The tan one is airsoft. When I don't have time to clean a squirrel or it's out of season, there is no better tool to keep a squirrel off a bird feeder. You have no idea what fun is until you full-auto airsoft a squirrel. Through the yard, up a tree, the plastic BBs follow.
View attachment 427581View attachment 427582View attachment 427583
Is it wide enough to hit 2 studs or do you have to trust drywall plastic anchors?
Brsckets are 16 inches on the dot. I purposefully screwed in the corner screws outward. I hit studs on both ends. You're supposed to use 8 screws per bracket with the included drywall anchors but I didn't. I only used 4. It's not going anywhere.
I've seen too many that are only 12" and you have to use a set of plastic anchors.
I'll look into these, thanks.
