"I thought G18's were illegal here................"
Just for clarification.
Glock ‘Switch’ several variations and easily bought overseas, will make any Glock full auto.
G18 designed from the ground up as a ‘machine pistol’ and used by certain Fed-Gov organizations.
I can see that.......
Put a couple hundred rounds through it at the range. Very consistent and accurate. Mostly shot at 10 yards. Love how the cylinder blues at the edges…
Nice bag...... what's in it?Finally, took about a month to arrive.
Is it wide enough to hit 2 studs or do you have to trust drywall plastic anchors?My wife is sick of my critter guns being all over. Found a solution. VEVOR gun rack. Simple, easy, cheap. Ready to rock and roll. The tan one is airsoft. When I don't have time to clean a squirrel or it's out of season, there is no better tool to keep a squirrel off a bird feeder. You have no idea what fun is until you full-auto airsoft a squirrel. Through the yard, up a tree, the plastic BBs follow.
View attachment 427581View attachment 427582View attachment 427583
Brackets are 16 inches on the dot. I purposefully screwed in the corner screws outward. I hit studs on both ends. You're supposed to use 8 screws per bracket with the included drywall anchors but I didn't. I only used 4. It's not going anywhere.Is it wide enough to hit 2 studs or do you have to trust drywall plastic anchors?
I've seen too many that are only 12" and you have to use a set of plastic anchors.Brsckets are 16 inches on the dot. I purposefully screwed in the corner screws outward. I hit studs on both ends. You're supposed to use 8 screws per bracket with the included drywall anchors but I didn't. I only used 4. It's not going anywhere.
