Jkzinger
Need some advice on how all of you with the hardcore Dynatrac ProRock 60 installed your front brake lines. How mine are attached after I installed them seems
to be pinching the brake line while turning. It will eventually wear through. Did you get a different brake line without the 90 degree bend or did you mount it differently? Thanks!
to be pinching the brake line while turning. It will eventually wear through. Did you get a different brake line without the 90 degree bend or did you mount it differently? Thanks!Sent from my iPhone using WAYALIFE mobile app
