nmwranglerx
I've recently been hearing an intermittent knocking sound coming from the rear of the jeep. I finally had some time yesterday to try and diagnose the issue. What I found was the the axle shaft on my driver rear side moves in and out even though the retainer bolts are totally tight. Any idea why the axle could be doing this? Improper tone ring/bearing install? I pulled the shaft and the order of items looks correct. I'm wondering if the tone ring was pressed on too far? IDK but I was thinking it must have something to do with the bearing set up. Here's a short video:
https://youtu.be/VEWZAM3lFjA
Wanted to add that there is no sign of leaking and the knocking sound seems to only happen off road.
