I have a 2 door X that I installed Rubi rock rails. After the lift and larger tires, I'm thinking about running boards or steps. I'd like to keep the rails (dislike exposed pinch seam) and add running boards or steps over/with them. Possible? Suggestions?
Only issue is if you use the Jeep on the rocks, you'll smash the steps up. The LOD signature sliders may meet your needs as they come with a step and are a slider as well, however, they still show the pinch seam a little. You also could get any slider and paint the pinch seam black to hide it.
Those look really nice on there. They only question I have is, why aren't they pink?
I've located a pair of Sahara running boards, which have a step built in. Would they work, to cover pinch seam and an step?
No protection tho, I think they're plastic?
Is it possible to leave Rubi rock rails in place, and add Sahara running boards?
They will cover the pinch seems asthetically but that's about it. You'll have no protection on the trail.
I run the Mopar Enchanced Rock rails. They have a bar built in that my wife uses as a step on occasion and I use when putting my soft top back on. I'd recommend them if you can find them second hand.
You can see them pretty well in this photo.
Moore hide a step works with Ruby rails and are removable when wanted.I doubt it, judging by his random video and having the factory rubicon rails before it looks like they both mount at the same location on the pinch seam.
https://youtu.be/jkKUM01rBHQ
I may have found the answer... BARRICADE ROCK SLIDERS
Here's a couple photos that show both rails and sliders mounted
View attachment 262473View attachment 262474
