nsbluesman
Hi All:
Is it possible to install an external voltage regulator on a 2011 JKU? It just doesn't seem to work for me, are the field terminals on the alternator the same as older Jeeps or did they change?
At present it looks like the VR internal to the pcm is toast, it wont control the alt output so I thought I could just bypass the damn thing using a Dodge external VR ( one with two pins, and yes I made sure the 12v source goes to the correct middle pin..)
Frustrating me to no end. Should be a simple fix.
Thanks in advance
Colin
Thanks in advance
Colin
