RKJK10
Question. Do you adjust your coil overs, when you go that much larger? Can't you raise the height? Excuse me if that sounds silly, but I don't know much about coil overs.
That's the beauty of coilovers. If needed you can adjust the ride height for sure. In all honestly, I don't run coilovers and it's not that much of a difference going from 37s since you gain 1.5" of ground clearance and the other 1.5" fills up the wheel well. Proper bumpstops and an angle grinder to trim the pinch seams and whatnot is what's needed
