Closest/easiest location to wire these into?
The wires not plugged in would only prevent it from illuminating, right?
Would it be okay to tap into this little fan under the steering wheel for ignition? Turns on I'm acc
Now what the hell is that fan for?
Couldn't find a direct answer. But everyone was saying for climate control.
I'm having a problem. With the red/yellow wire, I also have a blue/white wire left. What is it for and what does it hook up to?
I bought the Teraflex mount to position the twin compressor under the passenger seat on my 2016 JKUR HR. I also looked at the Carolina Metal Master mount. They both position the compressor suspended from the mount with the compressor into the carpet. Once I mounted the compressor to the seat and put the seat back into the jeep, I was surprised about how much of each compressor was in contact with the floor carpet. Seems to me that air flow around the compressor should be important. There is plenty of room between the top of the mount and the underside of the seat. I decided to buy a mount from Innovative JK products which orients the compressor so the mount is between the carpet and the compressor and the compressor faces up. This allows plenty of room for air to pass around the compressor. I am not running air lockers and I plan on mounting the ARB switch to the seat frame without illumination (no blue wire with white stripe hook up). I can then open the passenger door, plug in my quick disconnect ARB air line and flip the ARB switch.
My two cents.
My two cents.
Nice write up, so there's no way in hell to put a twin compressor under the hood?
I've got the larger single and it just doesn't air up fast enough with 37's
Matthew
Going to attempt install on a 2014 jku tomorrow [emoji848][emoji848]
Go twin and custom make flame retardant hose
