They look great but a big hit to them will cause body damage - I have seen it happen.
Watch WAYALIFE YouTube Videos
WAYALIFE Jeeps & Specs
I take it this goes for all metal flares? I was considering the evos in the front and evo fenderless corners in the rear.
Do you recommend cutting the stock fenders? Are fenders a waste of money? I do not care, entirely, for the look of my Jeep, more so, the function. Is there any advantage of aftermarket fenders over cut-stock fenders? Sorry for the new guy question; just trying to figure things out.They look great but a big hit to them will cause body damage - I have seen it happen.
So I have been thinking about getting these does anyone here run them and how do you like/dislike about them
and my brother hit the same rock on Old Sluice with the trimmed flares and he received more damage but thats what ya get at 12 at night lolThey are great fenders and well supported, if you watch what your doing you will be ok. As far as body damage if you slide off something you would do body damage just as easy with the plastic flares. The plastic will just give you a few more inches before you hit the body anyhow.
Either way you go it is your jeep![]()
Personally i have had metal flares hit at rubicon and received this damage View attachment 254590 and my brother hit the same rock on Old Sluice with the trimmed flares and he received more damage but thats what ya get at 12 at night lol
Mhm. At least they do utilize the inner subframe not just bolt to the outer body panels like most of them doI went with the aluminum Poison Spyder front flares. There is an inherent risk of body damage with these, but I didn't get them for trail protection. I 100% chose them as a visual model accepting the risk of any damage if they take a hard enough hit.
sent from your basement
I'm rolling with a set. I really enjoy the look on my jeep. I'm not a fan of plastic bumpers/fenders. Just so you guys know there is some internal bracing that comes with the fenders. You are not just bolting them to sheet metal. Yes obviously if you hit anything hard enough there's going to be damage, but mine are pretty damn stout. I can stand on mine without any worries. I'm am more of a slower cautious wheeler though. I tend to work my way over and through obstacles vs a ton of skinny pedal. Would I buy these again-hmm not sure. I would probably start by trimming my stock flares and go from there.
This is great info. I just assumed (I know, I know) that the stronger the better. Will def be starting with trimmed stock fenders. Thx
Not at all disagreeing with you are saying. All I meant was that they do take a bit more of a hit than most. Personally while I am considering getting them at some point it will be the narrow ones so I am less likely to hit anything with them, and for looks not for protection. Aside from that I will be just staying with cut fenders for a while. And may well but some that have been taken off another jeep to see if I can get them cut a bit more evenly.There are the internal reinforcement braces, but they don't save the fender when you push in on it with the weight of the Jeep. All the photos Poison Spyder uses show them putting weight on top of the fender flare, which doesn't actually push in on it, and it seems to hold weight at that angle. But a hard hit on the trail from the outside of the flare will push it right in.
