Is there any way to come up with a calculation of 1" of scrub radius = __ ft of extra turning radius on a JKU?
Nice turn testing. [emoji106] So this is all as a result of the scrub radius. And no rubbing at full turn on Rubicat because the axle is wider though the BS is less, yes? That's some top notch made in the USA science right there!
Turning radius and scrub radius are completely different, and for the sake of discussion, unrelated. Turning radius is the tightest circle the car can turn in without backing up and doing a multi-point turn. The number is typically published as part of the vehicle technical specs by the manufacturer. Rarely is scrub radius published.
Front wheel end geometry does have an effect on the turning radius of the vehicle, but other things (non-axle related) have a larger impact. We did not test the turning radius on Rubicat before or after the axle was installed, but maybe Eddie can chime in with his impressions so far.
We will publish more info on this at a later date.
No, as Dynatrac posted the scrub radius is not related to the turning radius. The factors that influence turn radius are wheelbase, axle width, wheel backspacing.
The scrub radius is helpful for some other things though.
Thanks for the real world test. Only downfall i see is the selection of good wheels with that backspace that i like.
Or ponying up the money for a weird length spare shaft. But hopefully with this setup you're not breaking those shafts.Thanks for the real world test. Only downfall i see is the selection of good wheels with that backspace that i like.
I went from a stock axel with 3.5 back spacing with hydro ass connected to the tie-rod to a pro rock 60 with the psc connected to the knuckle and it seems it doesn't turn as easy compared to my other rig and its really hard to steer with my front locker on compared to my other one. Does this make sense? I know I have 40 now and wider axels and I'm sure it has to do with what this thread is talking about, but I'm not an engineer so I'm just try to understand this a little better.
Yup, makes total sense that it's harder for you to steer your ProRock 60 with lockers on especially being that it has Pro 60 steering knuckles and the back spacing on your wheels is most likely significantly less. They will dramatically increase your scrub radius and that will cause your tires to scrub their way around as they turn. This scrubbing or resistance will make it harder to steer. The stock axle on your other rig still uses factory knuckles with unit bearings and should have measurably less scrub radius. While a ram that is too short or improperly setup can limit your steering range, how it's mounted up shouldn't make a difference in your ability to steer.
Did you first add the 40s when you did that change too?I went from a stock axel with 3.5 back spacing with hydro ass connected to the tie-rod to a pro rock 60 with the psc connected to the knuckle and it seems it doesn't turn as easy compared to my other rig and its really hard to steer with my front locker on compared to my other one. Does this make sense? I know I have 40 now and wider axels and I'm sure it has to do with what this thread is talking about, but I'm not an engineer so I'm just try to understand this a little better.
I guess my question was, are you comparing the steering on two jeeps that both have 40s?No, I actually bought a new to me jeep that had the 40's and 60's so it was pretty neat having them both at the same time for a little while.
Reading through this thread inspired me to do some testing of my own. Thanks Eddie!! :crazyeyes:
Since I have a stock 2015 JKU and a 2009 Modified JKU I thought it would be cool to do a turning radius comparison.
Here's what I found..
So you're the dude who's been chalking up my parking lot......
