Evo Coilover setup help
onlyAjeep
Hello fellow jeepers!!! So I have the Enforcer pro stage 1 and I added the agm sliders. The passenger rear seems to hit hard. Not sure what the issue is. The coilover seems to bind??? I've messed with adjustments.. still messing with them...... I'm going for very little lift. Any info would be appreciated.
onlyAjeep
When you added the agm sliders, did you also adjust the rings because they will change a lot from the king sliders.
As mentioned post up some pics tho.
Agreed. A pic would be a big help but my first guess would be that the timing rings are off.
Yeah, that looks a bit too high. Are you saying that you're still having issues in spite of lowering them?
Yes. Still seems like it hits hard. I'm going to go over it this weekend. Set the rear preload ring to the top and adjust the lock rings to 1.5 and see how it is.
onlyAjeep
Update: seems to be better at 1.5in stop rings. Probably will do 2in. That should be OK with the agm slides.
onlyAjeep
