Devallee
I was reading through this http://wayalife.com/showthread.php?3861-Basic-Do-it-Yourself-Jeep-JK-Wrangler-Front-End-Alignment and had tried re-aligning my steering wheel and it worked great so I read on. I wanted to try out re-centering my front axle and checked under the jeep to see if I had an adjustable front track bar and I do. However, the pic and explanation said to disconnect the end that was mounted to the axle and adjust it. When I looked at mine, the adjustable end was on the side mounted to the frame. The axle mounted end was not adjustable. Probably a noob question but is it possible to be on there the wrong way? Should the adjustable end be mounted to the axle? Or are there all different types of track bars and I'm just confused for no reason?
