Benito
How does it steer locked up in the front with load? Have you had a chance to try yet?
So jealous man
i haven't had the chance to go wheeling however, i found a high concrete barrier and lined the front drivers side right against it, i was able to go lock to lock and shifted the jeep away from the barrier. A friend of mine has JK on 35s with stock steering and wanted to see the performance increase with the ram so he tried the same thing with his and could not steer in any direction.
on a side note i need to go back and tighten up a fitting (smaller leak) on the steering box and add teflon to the fittings on the cooler(small leak).
