xflstl
Clearly, an expert like you would know for a fact that the end forgings are what you were seeing bend and not the tubes.
Sorry, I'm far from being the badass that you clearly are.
It is of my opinion that not all 60's are equal or are made the same. What you chose to buy and broke may not be something I'd consider a good investment and I might recommend that people not waste their money on it.
I am trying to get clarification on your logic. If an axle can still bend or break with a sleeve , there by making sleeves worthless (YOUR OPINION). Then if you apply that to say C gussets, even someone with my limited experience (honestly it's limited) has seen C's still bend with gussets. Then they must be worthless as well. .. True D60's are not all created equal, they can all be broken... So by your logic if it can and might or will still break it must be worthless.
My point in all this? Its your opinion that sleeves are worthless. .. That is perfectly fine, many people share that same opinion. My opinion differ ' s and that's fine as well.
Just because you have the opinion they are worthless doesn't make it a fact.
