blackrubi14
You were right. Even on-road it moved around too much. I installed a second clamp down lower and it's fixed. And still easy to take out or put away.
Good to hear. Any pics of it with the second clamp?
Heck yea, that'll work!
Have you had a chance to use your compressor yet?
Now in comparison for this vs the 9.5 Warn powerplant?
I plan to get the Zeon 10 or 10s, thinking 10, then save some pennies and get the synthetic line later. Take the 980 bones for the winch, add in the 500 bones for the ARB twin, that is roughly in the ball park of the powerplant...
Either way, I need a new winch, and I need a way to air up some tires. So one item, or two....
I think the Power Plant is more than that isn't it? I remember it being 1700-1800 when I was looking at it. What are the PowerPlant air up times? And can you run tools off the winch without a separate air tank? That would be a benefit as well.
I am also assuming I would need to buy a hose, plumbing, fittings etc to make the ARB useful? I like the idea of the twin, I really do. A dedicated air source, I don't need it for lockers yet, or maybe ever... I feel as if a tank would come in handy, but at what size, where to mount etc...
The only downside to the powerplant is that if you want to run air lockers your still going to need to get at least the small arb
Wow. I didn't realize that. Why is the extra compressor required?
.Cause you can't hook up the air locker solenoids onto the powerplant so you need a small compressor to fill the small arb air tank to then hook the air locker lines up to.
In my set up below you can see the small air tank needed to connect the solenoids to.
Coz - A little off topic, but what mount are you using for the twin?
Bump. For those of you running the ARB twin compressor. What's a good working hose system for airing up tires? I like the idea of the inline gauge too. Basically if I buy this compressor, what else will I need for airing up tires (fittings/lines/etc)? I want to do it once and do it right. I do not have lockers, and don't plan on lockers.
Hey bud, take a look at Innovative JK Products. They have a hose system so you can run one air chuck under your passenger and driver side doors and air up all four tires to a set pressure at once. Check them out :thumb:
Has anyone done a passenger seat install on one of these? I just got mine delivered, and I'm a bit unsure on the length of the supplied harnesses.
