If the tires are not that much larger than stock then it would probably do nothing until you hit a bump or hit a fast turn and then it would trigger the system hence all the lights. Your programmer should clear that up once you get the correct tire size in.
In the meantime you can try disconnect the positive cable and touch it to the negative cable to clear out the codes and reset the system to relearn, it may buy you a little more time.
follow this:
1. Disconnect the battery by removing the positive battery cable
2. Ground the positive cable to the negative cable for 30 seconds to erase the electric charge in the capacitors
3. Reconnect the positive cable to the battery
4. Turn the key to on but do not start
5. Turn the headlights on
6. Turn the headlights off
7. Turn the key off
The ECU has now been reset to its factory settings. for the next 50 warm up periods the ECU will relearn the engine and driving habits for your driving conditions and the newly installed parts
