GCM 2
....... I read on jkf that that hole to the upper right of the gascap is for the installation of the carrier bracket and to not put a nutsert in that hole. I see you have put a nutsert there so hopefully that is correct. Just wondering because mine arrives tomorrow.:rock:
Like MTG says, if you aren't running the EVO carrier, then you just install a nutsert until you do the carrier install. The carrier hangers are bolt-on and all that part of the install can be done longer after the rear quarters have been done. I run no carrier but have those same holes with nutserts installed.
