Is anyone running this kit, if so how do you like it or if your running one like this what brand is it im getting ready to finish getting all the things i need for my lift kit.
Thanks
Not to be an EVO fan boy, but get the EVO version from OREs website or give Drew a call. They are hella cheaper ($80 ish) and I believe already come powdercoated. [emoji106]
Wow! $70 powder coated for evo and $150 powder coated for the nemesis. That's crazy!
Im going to have to look now didnt think they made a kit for the front
The evo ones dont look like they turn it the right way like the Nemesis ones
Currie makes a lower shock relo kit very similar to the Nemisis ind ones for 51.95, powder coated and all that.
CE-9807FSRK - JK Front Shock Relocator Kit
While your looking JKS has a kit too, I don't remember what I paid but it worked well
The nemesis ones also move the shock mounting point up 1/2 inch. The other brands keep it in the same spot. Probably not a big deal but if your tolerances are tight already make sure the shock won't bottom out in the new position.
I think it's moved up to compensate for moving it out, while others by leaving it in the same spot and moving it out is essentially moving the mount down.
Other note, I def prefer the way nemesis and JKS turn the mount to help with binding
That's is the only other one I've seen turned that way like the nemesis.
Wichita way is the correct way to have it turned?
Someone can correct me if I'm wrong but I do believe this Currie kit (CE-9807FSRK - JK Front Shock Relocator Kit) relocates the top of the front shock, not the bottom. This part also requires a shock with the same mount on the top as the bottom. I had some old pictures of my 2008 with this on it but I can't find them on our computer.
