mudmobeeler
Everybody talks about the Rear 60 but I wonder how much stronger is the Trail or PR60 running on the weak side of the ring and pininon vs the stock 44 running on the strong side even if it's smaller...
The trail 60 is still a semi float axle so while it is stronger due to a bigger ring and pinon, you can still have the issue of breaking an axle shaft and it coming out of the housing. Don't get me wrong, it will still be stronger.
The PR60 is a full float axle meaning the axle shafts are only powering the wheel and not supporting the weight of the vehicle. The ring gear and pinon gear are bigger than the 44. The axle shafts are also bigger and the axle housing is as well.
