How simple was the install of the Switch Pros?
It is actually fairly simple, more so if you don't have a dual battery setup. The firewall location in my situation was a little tough with the dual battery set up. I couldn't use the wide mounting plate that utilizes the bolts. So, i just pulled the battery forward and slipped it in without the plate. Thought about making my own mounting plate but it isn't going anywhere. I think the unit itself is its own heatsink so probably dosen't need the mounting plate. I plan on mounting the button control panel on the A pilar above the Genesis G-panel.
