Pixel
Ok so first a little backstory to this. Was out on a little trail a little while back and I got hung up on a rock that was under some small tree branches/leaves and tore off the passenger side lower control arm bracket. Now at the time I didn't know how badly it was damaged it was driveable (a little off, figured I needed new tie rod ends and alignment). It wasn't until I had it back home and got it up on a lift and saw what I did.
The vehicle is a 2007 JKU with 104,XXX on it so I did the ball joints, front axle u-joints (worn out) and then figured I would go get the alignment looked at. Unfortunately I saw that the control arm bracket had been completely cracked and bent outwards, no bueno.
I purchased some Rock Krawler front lower control arm mounts (RK00396JK) and had them installed along with a TeraFlex FlexArm kit (couldn't beat the price so I went for it, I know some guys hate their stuff but..) So after this was all put back on I noticed something was not right. My sway bar is completely shifted to the passenger side forcing the outwards hitting the front coil springs and also the bump stop rubbing on the spring.
What should I look at to determine what else this needs tie rod? drag link? or could the sway bar just gotten knocked out of place? Forgive my ignorance but suspension work isn't my thing, I would like to learn more however. I am going to bring it back to a suspension place that was recommended to me however I would love to find a starting point before I do that. I have attached several photos, I do not know what specifically one would ask for so I took several. If you need something specific just let me know what you would need a photo of. Any help is greatly appreciated as I did not budget for this additional expense. Many thanks in advance.
I added white lines so you could see how skewed it is.
Passenger side
Driver side
Track bar
Track bar again
What appears to be the sway bar shifted?
Passenger side tire out past fender, driver side not even to the fender
Passenger side
Driver side
Track bar
Track bar again
