branman
Call Chalmers at Caliber Collision northwest-anaheim.
Will do - thanks again - great info :beer:
Going with the bigger blacker!!!!
You mean you actually wheel your jeep?
Looking good Brandon! How do you fix that?
Not completely sure yet - I have 4" bump stops but probably need a little more - My ride height is set pretty low as we did not want to set it until I get my tire carrier on the rear. I'm also not sure what roll the timing rings play in the front as both springs are 250's - My guess is to raise my ride height a little and add a little more bump stop and lower my timing rings. or maybe limit my steering stops - to be honest I'm not sure.
Got around to installing my 20" Light Bar for the bumper with EVO Bracket
NOTE: This bracket is made for the "EVO Pro Series Bumper" it is NOT a "Pro Series Bracket" Read the description carefully - This will work for my application on a Quarter Pounder Bumper but the mounting surface is NOT bent at 90* it is more like 100* However my winch controller is in the way so I used it in reverse.
Bolted it up and realized I am out of wire - so I will wire it up tomorrow :doh:
Looks good! Are you going to wire it to your fog light switch?
Looks clean Brandon, great work!
Nice!! Bright?
Looks great! When you get it wired let's see how bright it is. I really like the look of that.
The bracket is so clean and the bumper is so dirty.
Gave Eeyore some wax today - made an attempt to buff out the pinstripes, got all but 3 gnarly ones but it is nice and clean now:thumb:
“Most likely get it dirty again, anyway.”
