JRied
Hey I need help again? WTF is new right lol decided to check under my jk to see if my new skid system had any beauty marks being that I tore a control arm mount off and I made an unfortunate(?) discovery. Idk what this greasy oil is. I checked my oil level and transmissions fluid and there full. So was all the other ones that wouldn't really have anything to do with this (power steering, brake fluid, etc etc). Was hard to find the source but at first it looked like my oil pan had a leak but the seal, bolts, and drain plug are all clear. It had a lot there as you can see in pictures. Idk proper terms so forgive my noobness but what looks like where my motor and trans connect is leaking or maybe that's just the trans, again idk. You can see the seam between this part I refer to is also greasy. Any idea what's going on? Also looks like the new yoke I installed on transfer case leaked. I torqued it down to 160 ft lb torque and use rcv silicon on edge and locktite on threads, but you can see the splatter above it in the pic. That's problemo número dos. But that I know what's wrong, or I think. Here are some pics.
PS thanks wayalife crew and members you guys are awesome
