ERAUGrad04
It's 5' The one I have is 5" shorter (so to speak :dohit has a shorter lower shaft. I found the fire stick tough to tune with a spring and in Arizona a spring is a must for all the low hanging brush. This antenna was easy to dial in and I was able to get SWR down to where the needle would barely move across all channels and with the same wiring the best I could get was 1.8 across all channels with my firestick. We will see but from my experience with the people with the wilson I can hear them miles further then then can hear me and at times I am a no show while they chat away. - so hopefully I will see some improvement.
I'm sure this whip will fly around like crazy but it won't be such a sever jolt as the FS on a spring.
Do you have a link to the antenna Brandon? I've tried two different firesiks (3' & 4') and the best SWR I can achieve is ~2 across all channels. I've wrung out ground and the antenna cable and all checks good. Hell, I even took a jumper cable and clamped it to a bolt on the tailgate and a bolt on the tub to to rule out ground issues!
