cozdude
Guy with a Red 2-Door
Oh I was under the impression that I helps take some of the pressure off when the gate is closed because the tire sits a little bit on the plastic. Maybe I should just pull the trigger and take it off.
if you run a big enough tire that it sits on the bumper it will actually help the tailgate. it will help the tire from not jiggling or moveing even more so than the tire just sitting firmly agaisnt the bump stops. EVOLander is a great example of this. its running a 37" trail grappler and ATX slabs on the stock carrier for almost 40,000 miles. yes the stock carrier. :yup:
