siphon6
SKF hub bearings are put through rigorous testing to make sure they meet or exceed OE specifications. These tests have proven life expectancy of 100,000+ miles, built using OE sensors, premium seals since SKF acquired Chicago Rawhide some 10+ years ago, 100% tested to the actual OE specs per part number, precise bearing preload from the factory. Here is some more info: http://www.skf.com/binary/30-147232/457284.pdfWelcome to WAYALIFE! I see that you've been on here for a while now but glad that you've finally decided to post up. As far as the SKF hub bearing goes, is there a specific reason why you would recommend it over Timken?
