Not a person out there with some knowledge on that angled hole on the EVO bracket. The example is in the last pic that Strizzy posted up.
Thank you for posting up Strizzy. :thumb:
The 8 little black ones are for the brackets that move your sway bar back. Look at picture 2 and u can see the silver bracket between sway bar mount and frame. I think you listed where all the others go.
They look short yes but trust me that's all they need to be, four of them only thread into that bracket and have to stop before hitting frame. The instructions don't say anything about it you are right.
Aren't those two long bolts the frame ones?
The two long black Allen heads are the bolts that go up through the factory shock mounting holes then through the EVO reinforcing brackets. You should have 4 of them (2 for each side), do you only have two?
Make sure you learn how to install those, you can do mine while I supervise from my lawn chair, lol
