ChrisB said:I love my powerplant, I would buy it again, however it does not work very good with power tools. I have the tank. It works for the initial hit, which may work to loosen a really tight bolt. But its not something you can run powertools from.
zzekeman said:Can you use the Powerplant to run ARB air lockers?
Indefatigable said:No.
Simple reason, the motor spins the compressor when operating the winch. It needs to be unrestricted discharge during winching operation.
Its an either-or situation.
This is what the WARN rep told me years ago when the winch first came out. They were dealing with failures as the compressor chuck was left hooked up during winch operation (the air chuck was plugged in to keep junk out of the receiver).
Maybe something has been changed since?
the Yes answer would be if you used the powerplant to charge a tank and then disconnect the powerplant from the tank.
I run the Warn 9.5ti. (9.5cti now ?) I've moved trees off the trail, winched myself off of rocks, I think it's the power plant platform, just without the compressor. It is powerful enough to pull a heavy Jeep when a snatch block is used. I use synthetic winch-line and haven't been disappointed yet. I had a MileMarker and it failed me after a year. :grayno:
Lots of people I know run the Power Plant and I wish I would have save up a little more to get one. But for now I'm happy.
