you have regular bulbs? mine said that when i put led lights with no load resistor.
That is actually kinda cool that comes up to let you know.
Yea i thought same way when I got first time..after I spent $100 to fix it and got same problem it is not cool...
does your light work? i unplugged my battery and that message went away.
Actually if the signal show consistently, it'd be better.. It's on and off ... May be connection problem. Last time dealer said had some cam sensor problem
surprised no one mentioned blinker fluid yet:crazyeyes: iwas gonna say if you have a tow package check the harness by the muffler, but sounds like something different with sensors and stuff.:thinking:
The shipping fluctuates a lot... sometimes on schedule, sometimes off...I just bought a quart of blinker fluid from some guy in China. Only $59.99. Its been a month though...strange it has not arrived
View attachment 74668This is what dealer did to fix this problem.
They replaced a cam sensor which was causing your check engine light to come on. Not related to turn signal lamp replacement.
I'd take it back since you are still having issues with the lamps and have them fix it right.
Thanks! But worse thing is engine light problem happened again after fix that..
I'm going tomorrow hope they can figure out..
