Yes!! Thank you all for your input but every single one of us was wrong :crazyeyes: ...
It was just corroded battery terminals, it didn't have a good connection. That is why we would get it sometimes to work then other times it wouldn't. We were stumped and baffled as to why we got 12v on the multimeter when testing the battery but still wouldn't turn on. Washed up the terminals and BAM worked like a charm! This thing airs up my 35s no problem LOVE IT! Besides my stupidity this write-up worked wonderfully. Thank you Eddie for taking the time to write and post these up! :beer:
How well does this on board air stand up for locker use and filling up 37s, has anyone had any problems or had it break! i like the price and the kit but am scared that it will get a ton of work filling 37s!
great for lockers but slow for 37's from what im told. the twin would be faster since its 100% duty cycle for airing up and the same for lockers.
I was airing up 37's with the one in this write-up and it would take about 3-4 min a tire to get from about 15 psi to 30. Granted, my PowerPlant will do that in half the time but still, I didn't think it was that bad.
that isnt to bad then. i just like how my twin does it in just over a min for my 35's lol
i remember Don complaining about the diference in the powerplant's fill time to the fill time with the single when he was helping me fill my tires last fall when he came out with us. i think that is what made me get the twin lol
Finally got around to installing the compressor. Fired it up to take it for a test drive around the block and now my Traction Control dummy light is on and will not shut off. Anyone have any ideas as to what might have happened?
Just wanted to make a quick addition to this writeup after finishing the install on my 2014. First off as someone mentioned earlier I found it nearly impossible to install the mounting bracket and then the compressor. I ended up removing the bracket, mounting the compressor to it, and then bolting them up as a single unit.
Second, I used the Rugged Ridge a pillar switch panel for my install rather than the Daystar. Several people have mentioned they had a difficult time locating a place to connect the blue/white wire. Rather than attempt to run a wire over to the window switch area, I connected it in the drivers door wire harness to an orange/grey wire. Seems to be working well.
That is all. Hopefully it helps someone out.
Hey folks, thought I'd add some pics / explanations to Eddie's write-up. Considering I have a 2014 JKU Rubi-X with the new Evo mount, my install looks quite a bit different. I followed the original write-up as close as I could however, there were some things I just had to change or else I would not have gotten my compressor under my hood. I hope the pics help for all of you out there that have a 2012+. Needless to say, I'm waiting on Northridge4x4 to get me an air filter because ARB apparently thought it'd be a good idea to leave it out of my box.
This is what the unit looks like installed behind the master cylinder. ** I had to use a Dremel and cut the back two protruding carriage bolts (closest to the fire wall) to get the mount to fit. No one that I know of had mentioned this before so I have no idea how you managed to get the mount to fit without trimming the carriage bolts. **
Instead of mounting the relay vertically using a zip-tie I decided to bolt it here using the pre-existing bolt. Worked well and I didn't have to drill/tap anything. Why no one said this before, who knows...that's why I took a pic of it.
I had to relocate the horn. I know some folks had mentioned this before, but no one attached any pics so I had to get creative. Works like a charm!
I used the original horn mount and just bolted it on using the driver's side master cylinder bolt.
Instead of running my switch wires in from the passenger side, I simply did the same thing as the write-up described but went through the driver's side.
There wasn't a good pic of the isolation switch wires coming up from the bottom of the console, so this is what it looks like. There was just enough play to wire the switch.
These are the remaining two wires everyone seems to have difficulties with. I'm assuming since I'm not running more than one switch (no air-lockers) I'll run the orange wire back to the battery. If that doesn't work I'll run both wires back to the battery to give my switch light power.
I hope I've helped some of you out there like me who had been scratching their head. This is a good write-up, but it definitely needs some updating for the 2012+ JK's out there. Thanks again!
You're a little arrogant with your first real post, aren't you? Just in case it wasn't "mentioned".
Really? Sorry, guess I didn't know that if I hadn't posted a bunch I didn't know what I was talking about. Let me know how many posts I should have before I try help others.
