Markymark420
I was replacing my Drag Link End on Tuesday night when I noticed that my steering box's sector shaft has axial play (in & out). The castellated nut on the draglink is torqued to spec (75 lbs/ft IIRC) and I ensured that the play was not within the joint itself by placing my fingers above the pitman arm, between it and the steering box, when diagnosing. I do not have a dial indicator @ home, but if I were to guess there is probably ~0.060" of axial play and a noticeable clunk associated when applying hand pressure up/down on the pitman arm.
Question: Does this indicate that my steering box is toast? Would I be able to adjust the pre-load to eliminate the play?
Any advice would be greatly appreciated.
