drop ship.
Same difference. In other words, it was available and something they could sell right then and there. Not that this is a bad thing, just trying to put things into perspective.
drop ship.
No experience with it personally but it's more than just a bracket. You mount it to your bumper. You will need to either modify your stock bumper to accept it ( I believe I've seen people do it not 100% though) or buy the AEV rear bumper.
"Acquisitions"? I'll assume you meant "accusations" and to that, all I can do is show you PROOF of what others and I have seen. Clearly, TeraFlex is aware of it enough that they have since modified their bracket and offer it to those concerned enough to contact them and request one. As far as vendors go, again, they are just supplying you with what you've demanded. Certainly, you have faith in what you got. I just hope you'll take the time to keep an eye on it just in case - for the sake of everyone on the road.
We already have the AEV rear bumper and have been looking into the bracket. The Bracket goes with the bumper but you don't necessarily need to purchase both from AEV. We have been researching their products and they seem to be a solid build however, we definitely wanted anyones experience with the bracket specifically before we drop 750.00. I'm pretty sold on the product already (especially since we have alot of their stuff and it's USA built) but, definitely want to hear from experiences since word of mouth in the Jeep world is a seriously valuable resource![]()
To kind of bring this back on topic, you can install an AEV swing out tire carrier without having to buy one of their rear bumpers. It'll work just fine with a factory bumper and still take the bulk of your spare tire's weight and put it on the frame. Best part is, you still get a single hand operation and can do this for about the same cost as a TeraFlex tire carrier. Just something to consider.
Even if you were a fanboy of AEV, I would be the first to say that their swing out tire carrier is a very good design and one worth considering. Same can be said of Expedition One and even the newer LoD carriers. The only thing I've never understood is the AEV rear bumper. While I'm not a full width bumper fan for practical reasons, I do think AEV has one of the cleanest and well designed ones for the front bar none. I just don't understand why they didn't create something for the rear that compliments it. What they have now is nice but it looks like it's made by another manufacturer.
Will this work with the EVO D-Ring/Frame Caps? I like mine too much to give them up.
LOL!! Oh, I know it's made by them and like I said, it's nice in its own right, just weird that it looks nothing like the front. It just has the look that it's made by someone else.
Having said all that, if you wish to continue this conversation, I would be grateful if you would just start a new thread. Or, I can move your posts and make it a new thread. I would prefer to keep this one on topic.
In my stock mounts "defense" I think it may have been hit or something by the previous owner as I noticed it right after we had purchased the Jeep.
I don't see why not. The AEV tire carrier simply attaches to the frame and you still have that :yup:
Thats why I was torn between replacing it with a stock carrier or moving to the smittybuilt. I have faith in my stock hinges so either option would work for me. I just couldnt find any evidence to why the stock carrier broke. One thing I did notice on the stock carrier tho is that the white metal or cast aluminum or whatever it is they make them with has really been disintegrated by all the salt on our roads... likely not an issue for 95% of the people on here but with all the salt they dump on our roads up here it eats everything... not the reason why the stock carrier broke however. Weird part is the tailgate isnt dinged or anything either from a possible hit. Its a weird one im sure, just another reason to always give your vehicle a good circle check.
and here is the smittybilt tire carrier with my 35" tire on... thought it would be slightly better then replacing the broken stock carrier with another stock one but I could be wrong... only time will tell. Also might be a better option then the terraflex carriers that seem to break very easy, I know its a much cheaper option.
Strictly speaking from a physics perspective: I don't like these carrier/mounts. The stock carrier controls the "wiggle" at bump-stops that are distributed across the door. The Smitty carrier put's all the "wiggle" control forces on the face of the carrier and transmits it to the carrier mounts. I have seen three cases of the spot welds failing and/or fatiguing and all three used the Smitty mount with 35s. I know of several other guys running 35s and one 37s on the stock carrier with the Daystar bumps and they haven't had an unprovoked issue, (hitting something).
Thats good to know. As Eddie has stated the Factory Carriers hold up very well, and I have never heard of any factory carriers breaking other then my own. I thought I would try the smittybilt and see how it holds up (checking it often) if or when it breaks I will be looking into other options (likely an O.E or a bumper mounted carrier) . I just thought I would show my factory one, and its crack as I said I know salt isnt the reason why it broke, likely took a hit as some point in its life.
Just listen for a bunch of squeaking and creaking coming from the gate... It's the first sign of spot weld failure. Personally, I would try to find another stock carrier and use good bump-stops over running a Smitty one, (Because of the failures I have seen.)
