Lookin good man! My only thoughts, for anyone planning to run an sPod in their rig, that bracket and an sPod may not both fit.MORE has an under the good bracket for the twin. They say it's good for an '07+ so it should cover all model years. I just installed it in my 11.
Sent from my iPhone
In my rig (2013) I don't think it would. My sPod mounts to the back of the CPU and needs the same space as that bracket. However, If I'm wrong, a stronger air compressor could be on the wish list!It should. Spod mounts farther forward.
I don't think it would fit either. Especially if you installed an air locker manifold right in front if the compressor.
That's a deal. B/c I don't have enough folks eggin' me on the pour more money into my Jeep!it should fit. there is a good amount of room under the mount. next trip i will let you take a look at it.
Awesome Rick. Please let us know how the install and fit goes. I assume your using it primarily to air up tires and maybe the occasional air tool use?
I have it mounted using the under seat bracket. It's mounted under the passenger seat.
I was originally going to have it installed above the rear wheel well. The shop didn't want to put it there because they didn't like extending the electrical all the way back there.
It works great! I have it running my rear ARB locker and still airs up tires fast. It has never overheated. I had an Viair 400C that would overheat after 2 tires, even if I didn't use my locker at all. I couldn't wait to get rid of that Viair.
Wow, that is snug up against the sPod. Why does that bracket push the compressor so far forward? It looks like there's a ton of space to back it up closer to the firewall. Does it have anything to do with access to the brake fluid? My ARB CKMA12 sits damn near on the firewall.I have the Twin under the hood with the spod. It fits if you dont use a manifold for lockers. I had the small arb and kept the bracket which would be good for the locker manifold on the other side. It's a tight fit and the compressor gets hot just from the mount location. In this case a bit too hot for what I like, so I'm planning to move it under the seat.
