DallasJKU
strike that ... you aren't allowing people to pm you ... soooooo, how shall I contact you ?
I didn't know it was turned off. I'm at work and I will turn on around 9pm. Thanks.
So, for someone like me who has had 35's envy ever since I got my 33's, now I wondering if I could squeeze 37's under my 2" JKS JSPEC lift (2.5" actual) after I trim the fenders or get Bushwhackers. What is the minimum about of lift needed without rubbing or sacrificing flex?
Nice. I just ordered my 37 NITTO trail grapplers today. Should be here next week.
Are those of you running 37s using wheel spacers? If so how big or how much are you running?
How many guys run 37's with the D30 still up front? And what kind of mods would need to be done to it so that it can handle the 37's? Regret not getting the rubi every day :doh:
My buddy ran 37's on his D30, it can be done, but saying that, know that it would only be a matter of time before the stress from turning the 37's snaps an axle shaft, or worse a sector shaft. I run 37's on my D44 and know it is also a matter of time before my stock shafts snap and I plan on upgrading steering to Hydro-assisted eventually.
To answer you question, gussets are a must running anything larger than a 33" tire, I wouldn't recommend sleeves as I do subscribe to the theory, as does WOL, that the factory housing is plenty strong. Matter of fact, the knuckles and the housing on the JK D30 and D44 are the same, only difference are the internals and the pumpkin. :yup:
