circlepete
What's a good starter recovery kit to carry for the daily driver jeep..thanks
www.wayalife.com
Thanks...I thought I saw this once before...but i couldn't find the thread...lol![]()
RECOVERY GEAR : A Must Have Before Hitting the Trails
If there's one question I get asked all the time from new Jeepers it's, “what’s the first mod I should do to my Jeep?” And, my answer to them is always the same, “recovery gear”. Fact of the matter is, whether you’re new to the world of off-roading with a right off the show room floor stock...www.wayalife.com
I would get a soft shackle long before I got a j hook.For sake of attempting to recover a non jeep or 4x4 with recover points I also carry a J-hook. It allows you to create a tow point using most holes in the frame or unibody. I was going to get an RTJ cluster but was told by the guy I bought it from that the J-hook would work in 90% of situations and takes up less space.
Not sure how you could attach to a car frame with a soft shackle. The J-hook just gives you a way to create an attachment point for a tow strap or winch if you can't attach the hook anywhere. Tow truck drivers use them all of the time.I would get a soft shackle long before I got a j hook.
Tow truck drivers also use chain and steel cable. Doesn’t mean it’s best for off-road recovery.Not sure how you could attach to a car frame with a soft shackle. The J-hook just gives you a way to create an attachment point for a tow strap or winch if you can't attach the hook anywhere. Tow truck drivers use them all of the time.
Yes there are safer methods out there but if done correctly it can still be done safely. Jerking, yanking, snatching, etc is a good way to do it wrong unless the equipment you are using is designed for that. I wouldn't be yanking on a j-hook, soft shackle, or any type of cable. Slow and smooth all the way.Tow truck drivers also use chain and steel cable. Doesn’t mean it’s best for off-road recovery.
Indeed.Jerking, yanking, snatching, etc is a good way to do it.
^^^^ Good kitWhile this isn’t cheap, it’s a good start and convenient way the bag.
should have 1 tow point in the rear, it's below the bumper, driver side - unless you have an aftermarket bumper and it was removedI have front tow points, but none in the rear, and no trailer hitch. Sounds like I need soft shackles. What is recommended (make, size, etc)?
Sports don’t have them I don’t think.should have 1 tow point in the rear, it's below the bumper, driver side - unless you have an aftermarket bumper and it was removed
I need to get my eyesight checkedshould have 1 tow point in the rear, it's below the bumper, driver side - unless you have an aftermarket bumper and it was removed
It's there, walked right by it a hundred times.Sports don’t have them I don’t think.
Sports have it, it’s just black and blends inSports don’t have them I don’t think.
Soft shackle to the axle, or tree saver to the axle.I have front tow points, but none in the rear, and no trailer hitch. Sounds like I need soft shackles. What is recommended (make, size, etc)?
