Alright, back in the ground and rolling, think I got just about all the air out of it, felt great on the test drive, was pretty wild how responsive it is compared to how it was. I am running into a bit of a steering range issue, with how the attachment on the tie rod wants to sit, it hits the diff cover, I tried rotating it up but then the ram contacts the underside of the track bar bracket when turning passenger, so for now I have the steering bumps out and it leaves me about one inch of ram cycle on each end, which I really don’t like the feeling as I know it’s still pushing and you can feel it pushing but you barely feel it reach its end point.
I’m curious what you all would recommend, I’ll try to get a better pic tomorrow, but it’s pretty solid contact on the diff cover if I let it go that far. Was thinking I could go back to factory diff cover and see, or maybe a different tie rod clamp, also I’ve remembered reading about caster on here and Psc but not sure, so curious of any thoughts around caster in general or if it would help alleviate this issue and use the majority of my range. Pics don’t show the contact but just the set up.
View attachment 432489View attachment 432490View attachment 432491View attachment 432492
