In The Shop - Disciple Off Road
Those are pretty sweet looking :unsure:. But only half the brightness of the LP6 pro. Which I guess is the point. Does the included harness tap directly into the Jeep's headlight controls? I wonder if that harness can be used for the LP6 pro instead of relying on two aux switches.
Yes definitely not as bright but these were made specifically to run as headlights hence the DOT. Of course that kinda sucks for light output in off road settings but I can tell you, the standard LP6 on the road pisses off a lot of people.
The JK specific kit works as follows: If you have halogen lights from factory, then they include a seamless pigtail that plugs into the oem harness. If you Jeep has the factory LED lights, then you will have to run an independent harness that they offer (Lockout harness) to your switch system. This harness does still incorporate the high and low beam.
For the JL/JT, the full kits include the brackets and pigtail harnesses for plug and play install. You just have to order the kit specific for your current light meaning, if you have LED from factory or halogen.
I wanted to try these out so I can have real feedback/experience with them. If I do like them, I may move my current LP6's back to the bumper as they are awesome out in the desert.
Those were an option for the Sprinter a-pillar lights but I figured they'd be overkill. They look good though. Are those now a headlight option?
For an a-pillar, I would still use the standard LP6 for the light output. These were really designed as a headlight option. They are actually popular for some motorcycle applications as well.
So essentially what you're doing on mine but DOT approved light levels. With the DOT LP6 on a JK you'd still have to use the aux switches
Well we actually did the standard LP6 on yours with the lockout harness since at the time, these weren't released. If you want to do the DOT ones, let me know. Since you had halogen lights from factory, their pigtail kit will work to use oem light switches.
Actually im mistaken its the LP4 they offer but im sure you could put the LP6 but that's a big light. I went with the XL Pro for a-Pillar lights. Probably should have gone with the squadrons. The XL's are really big
No keep going as planned I was just thinking in the future if I piss too many people off lol. Good to know I can make the switch if I want to in the future though.
Oh yeah LP6 on the a-pillar is pretty big. The XL's look good their though in my opinion. They are also pretty dang bright.
Some of the new new from Baja Designs. Excited to try these out.
Damn, these are awesome! I don't remember how long I've had my LED (Heated) Rigids on, but it's been a while and they've performed well on several snowy mornings in Moab.
If these measure up, I'd get a set and swap them in.
Those look like something I need to try out! Let us know how they work out for you.
Having this brand new 2025 JL in the shop today really made me want a 2dr for some reason..
It’s in for some gears, wheels/tires and a Rockjock lift kit.
This is only the second time I have seen this style locker in a JL/JT, the first being Bandit, Wayoflife’s JT.
I also came to realize this JL had the newer full-float rear axles. Pretty cool set up. Essentially, you could pull the axle shafts in the event of a break and still mount the rear wheel to drive out.
This JL also had the FAD deleted from factory as in, it’s still a two piece shaft but has a block off plate with no motor.
My wife has the same exact jeep. 2024 though. Be curious to follow this build👍🏻
