OverlanderJK
Resident Smartass
I really like these tires and would buy again. I have the AT3’s.Have seen at work the Falken Wildpeak AT4W wear well. Get them in a load range E
I'm going to be needing tires before winter. 2021 F350. I'm looking for 35x12.50. Normal towing is around 9000 lbs, but occasionally pushing 20,000 lbs. Seldom go off road, but an AT would be optimal. Also, extra points if they're good in snow. Suggestions please.
Did you buy that thing new? That’s crazy wear if so.Had all the wheels replaced today on the trailer they just sucked, were worn out so I went with Hercules.
I did not. Not sure what prior two owners did but the tires were rock hard. This is 2022 trailer. Serviced the hubs pumped the pressure to spec 65. It was at 50. So will monitor going forward.Did you buy that thing new? That’s crazy wear if so.
Ah that makes sense.I did not. Not sure what prior two owners did but the tires were rock hard. This is 2022 trailer. Serviced the hubs pumped the pressure to spec 65. It was at 50. So will monitor going forward.
